different size ring?
  clio 03 1.6 16v
hi guys, i need a new abs ring for the rear (1.6 16v 03)
is the size of the actual ring differant from like the 1.2 models? or earlier models etc?
any fast replies are appreciated. thanks!
  clio 03 1.6 16v
remember the ring on the back insnt on the driveshaft it part of the drum, so surley it locks on, then to get it off it unlocks and u should just prize it off?
but is all non c/s rear rings the same size? if i keep driving with the abs constently kicking in the pump will eventually wear out..
  CB600FS
Count the teeth on your drums then get down the scrappy and get one of a 1.2/1.4/1.5/1.6 and count them.
Im 95% sure all non Cliosport drums are the same - the rear disc'd Clios use a totally different system to the rear drum'd Clios, its not just a case of swapping axles over (unless you want rid of the ABS anyway)
