diming lights
on high bass notes my lights dimm , this is when my system is up , its even worse when the a/c is on or the heater ne body got ne ideas ? help would be greatly appreciated!
many thanks
Justin
  don't
2 much drain on the battery m8
used 2 get it alot with my old ax gt, need bigger battery or a power cap
powercaps about £50-100 i think
or a bigger battery, bigger batterys always a gd idea :)
  Golf GTD
i get the same running 200wRMS x 2 12inch Subs and a 2x160wRMS amp.
"Bothered" :p Power cap would fix this then?
  don't
yea i think a powercap would help as it could supply the extra energy needed 4 the big bass lines, however if theres a pretty much constant heavy drain then not sure itll cure the problem
bigger battery or power cap way 2 go,
might b worth going on talkaudio forums and asking them on there b4 buying anything as theyll know everything u could ever want 2 know about ice
seperate audio battery is better than power cap.
but about £100 more. power caps would still solve ur prob easy tho :)
