Disconnecting auto levelling lights?
My drivers side is pissing about moving up and down and the rear beam sensor looks OK, so to pass an MOT I will need to disconnect them, what's the best way remove the fuse or just unclip from the headlight? I'll get the garage to adjust them manually before testing.
McGherkin
Macca fan boiiiii
Would be an MOT failure. 'Where such systems are fitted, they must work'
I'm not sure on what connectors the Ph2 headlights have but yes, unplugging the servo would work.
Aye seems that way looking at the VOSA rules for Xenons/HIDs. So it's either fit a pair of standard mk2 halogen lights and disconnect the auto levelling system OR fix the issue(s) on the car as it stands.
bashracing
Yeah, Just unplug the level motor on the back of the headlight and park facing a wall in the dark and set to the same height as the correct one
