Do i stick with carbon or paint my cover?
  VRS
opinions please! currently polishing up the frc and manifold plenham. dont know whether to stick with the carbon cover or paint my oe cover? also not sure what colour to opt for if i was to paint the oe one!
also if i do keep the carbon cover, im weighing up whether to cut a hole to allow easy access to topping up the oil! wht do you rekon?
thoughts and opinions welcome!
andy
  Turbo'd MX-5 MK4
personally I would get the oe one sprayed the same as the car and the strut brace, and change the hill bend for a blue or black one.
  Tesla MP3 2021
imo....when the covers are painted it can look a bit tacky and cheap....if you get the manifold looking like a mirror then i suggest to leave the cover of completely.
Christopher
  Z4M
Here's mine with the carbon cover and Samco hose kit.
keep it as it is imo, just get that metal polished! ;)
  VRS
what do you rekon about cutting a hole in it? its just that i have to take the brace off to remove the cover!
i dont really like them carbon covers personally..
think it makes everything look to dull and dark. but thats just my 2p's worth :)
not sure how much im gonna like mine colourcoded either really..
think they look ok silver..
just hoping my mate is sending off soon to have more bits chromed so i can throw some of my bolts in his order to be done.
Ali
  V6, Trackhawk, GTS
Chris you've got alot more polishin to do!!!!!!!!!!!!!!!!!!!!!!!!!
Leave it how it is...
  Lionel Richie
i'd have it sprayed diagonally with a blend fade from racing blue into carbon if you understand what i mean?
like this?
mint.. will be able to see the carbon weave through the blue where it fades too.
carbon copy said:
I like Fred's idea...
might nick it for my car actually. ;)
if you get them to thin the paint down a lot you should be able to still see the carbon weave through the silver in bright sunlight ;)
  106 GTi
Like the fade to, not sure on the diaginal though. I would fade it front to back straight across.
  VRS
what sort of paint would i need to use cos the cover does warm up after running it for a while? would i need a different paint to that which would be used on the bodywork?
Ali
  V6, Trackhawk, GTS
No. Std paint does fine...Mine's colour coded, No probs at all.
  VRS
im tempted to pop to the body shop thats doing my bumper and ask them to do it!!!! how much do you rekon it would be bearing in mind they will already be mixing some paint up for the bumper?
  VRS
GuyS said:
like this?
guy would you be able to do the same piccy but with the fade going upwards instead of diagonal like r-jay suggested?
cheers
no mate.. lol
took a while n i cant be arsed. haha
use ya imagination ;)
id say you should get it done for 40ish quid.
