Does tire 195/55 R15 fit without any problem?
  Renault Clio 172
Hi
Does anybody know, how the tires 195/55 R15 fit. Are there any problems, scratching ?
Best regards
Madis
  Renault Clio 1.5 DCI
I have 195/50/15 and they fit perfect. Still lots of space to a bigger tyre. Therefore I am sure 195/55/15 will fit. But the tyres diameter will be a bit bigger than standard.
  Renault Clio 172
Current profile is 185/65 R14. The roads in Estonia are in bad situation and therefore 195/50 r15 would be to much. The alloys can be damaged easily if drive through bigger hole :(
195/50/15 : Rolling diameter = 1760 mm.
195/55/15 : Rolling diameter = 1815 mm.
As I said before, and I think you already know, the 195/55 will have a bit bigger rolling diameter than 195/55. I am still sure that they will fit with no problems.
