door badges
  Clio 1.4 16v
on he doors where is says 1.4 16v do they do just pull off or is there a certain way of getting them off
spraying silver btw :) wannabe clio sport:(
sure, ill let you off since you are new
the side of the car where the badges are (ie 1.2, 16v, 1.4, 2.0l etc) are called bullets.
just below this thread is a guide, where someone asked the same question in terms of how to get these so called "bullets" off.
simply put, open your car door. push the bump strips (plastic parts protecting the door) towards the rear of the car. these come off.
once off, turn them over and you will see clips (three to be precise) holding the badges/bullets on to the door trim.
be careful when taking the bullets off as the clips can be quite brittle.
jamie
  E92 M3
i just got a screwdriver with some papertowels wraped round it and pulled it off didnt sctach the paint and didnt snap any clips and its a lot less of a fuk on than taking the bump strip off
can be done, but i dont trust screw drivers anywhere near my paint work for fear of the slightest slip!
