Door Speaker Help?
Car  (s)Low Dynamique
Need a bit of help, done various searches and I'm highly confused.
As far as I can work out, 13cm speakers are a direct fit, and there's a bit of work required to make 17cm speakers fit. Is that correct? If so, what power 13cm speakers could I run without an amp, still getting a decent sound?
Many thanks in advance,
Jake
Oh and I have a Mk2 Ph2 Dynamique by the way :)
You wont get decent bass out of 13" speakers. Either do the conversion to a larger speaker, or get a small sub in the boot.
Read the specs on the speakers before you buy them. No one can guess what they will take.
However, as mentioned.. Sub in the boot, decent HU with frequency cutting to the doors, done.
