Dougmal’s Supersprint!!!!!
the oe exhaust is 1 piece from cat back
yes it needs to be cut either that or the rear suspension needs to be dropped out
to fit back on just sleave the joint and gum it up its what renault do when they replace the exhust anyway
warranty is only affected if it can be traced back to the new exhaust been the problem if it is the problem just refit the old exhaust b4 it goes back in
dogmaul - cheers for the info, just another query.............
To cut the OEM, Where would I cut it ? At the point the backbox becomes the middle section (ie where Renault would cut it should the backbox need replacing)
I assume the CAT back end of the OEM bolts onto the end of the CAT
Do all CAT-back s/s zorsts come in 2 pieces to allow fittings without dropping the rear suspension ?
cheers
rich172
you would cut it just after it comes down over the rear beam going from the back of the car
with the supersprint race system you can never have the cat on it the center section just wont connect it has no flange
all cat back ones will be 2 piece id imagine
