Down on my power but not sure why?
  Bumder With A Buffer
Rather than having the feed in the fog light try locating it to behind the lower grill? Might help any s**t getting in there????
Thats where I was going to run mine too.
Greeny.
  440i + 182
Na, even more bends then! Ill probably remove it at some point but atm its just feeding air in the general direction of the airbox.
At least my car can breath properly now :) That + a new map with my RsTuner seem to be a good start, 'feels' better to drive now. 6500_5404.rst btw. Now running the same map as Gregg, was using the older 6400_2A07.rst. Back to fms next month probably to check things out.
So what .cal you running now then? Im thinking of changing mine to get rid of my lumpy idling and random stalling.
Coby.
  XC60-R.......V40-R
Sounds a Good Start Dan.... Do as much as you can before busting out the Bank Card :)
Did anyone buy any Oil on Sunday? I had the money but kinda just forgot so think I may just order some Silkolene as its the Favourite on CS.
  197
Took apart my airbox and.... my airfeed was partly blocked up.
Dan , with RSTuner you can also make a live data log. This problem would have showed up as a more than usual Inlet Manifold Pressure drop, > 30 mbar.
  RB 200 Cup!
After the EA RR day today my car only made 163 bhp/151 torque :/ I have the following engine mods:
  • 80mm ducting directy from foglight into standard airbox with a K&N Panel
  • 2.5" stealth system
  • de-cat
  • Rs-Tuner GrpN remap
I am currently running fully synth 0w30 oil which will be changed ASAP, but I dont know why im so low on power considering Gregg who also ran a 172 ph2 has basicly the same mods minus the foglight feed and a different airbox but made 173.5bhp! SAY WHAT :(
Suggestions?
my standard 182 only made 161bhp that day - stop complaining
mind you my torque was immense ;)
  ITB'd MK1
again that sounds like the cam timing is wrong. When they're wrong they seem to have quite a bit or torque in the midrange, but power peaks early and doesn't hold on well at higher RPM
Martin_172
decent torque figure, that must be the RStuner map at a guess! the 10bhp imo if other cars with same mods were running different mods would possibly be shabby inlets there is big gains to be had from matched inlets on some cars and not so big on others, didnt make too much difference on mine but then my standard 172 made 173bhp on a day others were making 160-170 odd
