drive shaft problems
  Ph2 172
as the tittle says im havin some serious drive shaft problems. i have had 3 in the past 11 months which is an absolute joke! iv spoken to the odd mechanic and have been told that i may need a shorter drive shaft as the car is quite low on coilovers.
does any one know what i can do to solve this problem properly?
cheers
tom
  ITB'd MK1
using the correct genuine shaft for the car? there's 5 different shafts for each side available depending on the specifics of the vehicle
  ITB'd MK1
the drivers side drive shaft keeps collapsing in the middle. does that help?
are you using a genuine shaft? there are 3 different versions of the 2 piece shaft, 172 ph2, 182, and 182 cup/cup pack. All are different lengths.
Non-genuine shafts only cover one of these lengths, and run the boot on the outside of the joint, which causes it to rub on the block. Split boot = grease leaking out = collapsed CV joint
  Ph2 172
ahhhhh i see. cheers danny that really helps. i didnt realise there was tht many different shafts. tht would also explain why the cv is constantly going lol.
thnx for your help guys :)
