Drivers side ABS sensor
DrR
  VW Golf GTD
Put some new dampers on the front today, think I broke the driver side sensor, grrrr.
SERV light and ABS light have both come on.
Easy to replace? How much is one roughly?
  BMW M135i
Easy to replace, mine are absolutely solid in the hubs though. Not a problem if its already shot though. Hold on i'll get you a rough price and part number.
  BMW M135i
Hmm strange can't get a part number for the drivers side that tallies to a price, only the passenger side. Ring the stealers is your best bet, says £35 for the passenger side one here so no major.
DrR
  VW Golf GTD
I noticed it was loose, before I removed the damper, think i knocked it to hard, now the SERV and ABS light is on, abs no longer works, I tested it hehe. Smokey!
DrR
  VW Golf GTD
Does the sensor include the wire? And how long is the wire? As i'm not 100% whats broke?
Yeah price if you don't mind :)
Suspensions loads better, my spark plugs didn't look to bad for 70k either.
  BMW M135i
If you follow the existing sensor then it goes to a plug behind the arch liner, you get everything from this plug. Sensor and cable are as one.
DrR
  VW Golf GTD
Oh god, i hate Renault plugs, due to the fact they don't unplug! Cheers for the info though.
DrR
  VW Golf GTD
Couldn't get the thing out today, so tried to help it aong with a hammer, stil wouldn't come out so put the whee back on, been for a drive and it seems to have fixed now :)
  BMW M135i
Mine are completely solid as well. I've tried to get them out to keep them out the way when doing stuff but they just won't budge.
