slammed the door recently?take the door card off and check the connections to the switch, may be slightly dodgy connection, the UCH may click but this could prevent it from working?
Mine did this i could control the passenger side window from the drivers side but the drivers side wouldnt work, it was the fuse that had gone simple. Check all your fuses!
any motor factor will sell the fuse,look in your manual to tell you which fuse in particular but iirc the fuse box is on the passenger side on the dash where the door meets it.panel removes
