Driver's Side Window Regulator
SWL16
  Clio 182
My driver's side window has stuck (luckily) in the closed position following a big clunk. Presume one of the clips has broken on the regulator.
Anyone know whether the regulator is common to the standard MK ii clios? (i.e. can I go and get a replacement one from the scrappy?)
Is there a guide for replacement somewhere, before I start pulling the door apart? (Can't seem to find anything???)
  PH2 172
Any 2 door Ph2 will do.
They are handed, so has to be RH driver side.
It`s common for the mounting bracket to fracture.
If the plastic clips have failed, this kit is available.
https://www.ebay.co.uk/itm/CLIO-II-ELECTRIC-WINDOW-REGULATOR-REPAIR-CLIP-FRONT-RIGHT/322545999067?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
