Megane DCi 147bhp/350nwm
Whats your view on them?
How well do they work?
EX DG CP Super Multi-coated Filters: Wide Multi-Coated Circular Polarizing filters
It reduces the glare and reflections from glass and water and other non-metallic surfaces. It deepens blue skies, and saturates the colors. The Sigma circular PL filter is designed to give best performance with AF Cameras. The Sigma wide multi coated circular polarizing filter (52mm to 82mm) is very thin, so it does not cause vignetting with wide-angle lenses. You can monitor the changes at different angles through the viewfinder as you rotate this filter.
52mm Slim£44.99
55mm Slim£49.99
58mm Slim£54.99
62mm Slim£64.99
67mm Slim£89.99
72mm Slim£94.99
77mm Slim£99.99
82mm Slim£119.99
86mm£129.99
95mm£139.99
105mm£159.99
52mm Slim£44.99
55mm Slim£49.99
58mm Slim£54.99
62mm Slim£64.99
67mm Slim£89.99
72mm Slim£94.99
77mm Slim£99.99
82mm Slim£119.99
86mm£129.99
95mm£139.99
105mm£159.99
