Easiest way to refit new aerial base.
  clio 172
Does anybody have any good advice about the easiest way to refit a new aerial base as mine got ripped off.I could do without taking all the headlining down if there is an easy way to do it.Anybody??Cheers!!!
Ian
  Focus TDCi
ph1 or 2? Ph1 is easy, just unclip the interior light and plastic panel and it bolts on under there. Ph2 I dunno, I imagine it's just bolted under the headlining.
Bluebeard
  Whichever has fuel
(assuming ph2 ariel at the back?)
Just pull the tailgate rubber off and the two rear plastic trims and you can pull the lining down enough to get your hand/arm in there.
No need to take it all off dude.
  clio 172
Sorry,forgot to put that it was a phase two.Thanks for the advice will go ahead and try to fit tomorrow.:D
