PH2 clio 1.2 16v
Hi my clio 2003 was having problems with fuel management I assumed best idea would be to buy same year and model of clio which I did.
So instead of just swapping the ecu i swapped the (ecu, key barrel, key decoder, throttle body, inlet manifold with injectors and uch.
Now everything is all swell immobiliser is not pulling up any errors. when i turn the key to full turn clio will short power, then the next time i turn it full it will send power to starter motor but no start and this will be the way it goes.
iam gonna stock everything apart from ecu,uch and key decoder/barrel see if its the same problem, i assumed the inlet manifold, injectors, throttle body would work as the donor clio drove a dream.
i also thought this would be clean sailing plug and play style. i hope i haven't damaged the wiring loom i'm as sure as i can be that tubes and cables are plugged in.
I will add the car sometimes picks up a short burst of life but is short lived as it dies soon after. almost seems like a bad earth is shorting it as the starter motor will only spin for upto 5 seconds a time.
cheers in advance for help.
