Ecu, uch kit
  2005 Clio 182
Hi,
When replacing the ecu, uch, key set from another car is there any special procedures I should take? E.g disconnecting the battery. Also will it all work and run without any coding etc? I have the exact same parts to fit.
Bluebeard
  Whichever has fuel
I've just done one funnily enough!
Disconnected the battery, removed old parts one at a time, replacing as I went, reconnected battery and that was it.
Didn't take very long either.
  172
You don't need the key blade , ignition barrel or door locks, just fob, key reader, ecu and uch. Very easy procedure
