Electric window
  Clio 1.2 authentique
Hi,
How do I get to drivers side electric window motor to check for a problem as drivers side electric window does not work. My car is a renault clio 1.2 2004 authentique.
Help. Thanks!
GrahamS
Bradaspinall Remove the door card, screws in the door handle, grab handle, speaker surround and bottom. Pull from the bottom, there is sealant around it so you have to pull pretty hard. Once the door card is off the motor is clearly visible. Easy job should take 15 minutes if you don't do this kind of stuff regularly.
