Right,
Just had an engine swap done on a 182 and upon first start the electrical fault light and engine management lights came on. Also the car is stuck in what seems to be limp mode. It won't go above roughly 3k revs and can't go faster than 50mph.
Fault code reader returned:
298 Pedal Potentiometer Track 2 circuit
267 O2 Sensor Signal after Cat
95 Circuit pedal Position Sensor
Coherence between Track 1 and 2
We took it back to the garage and got it cleared. Upon startup the car returned the 298 pedal potentiometer Track 2 circuit error again.
Now the codes would suggest that we replace the pedal sensor etc but I thought it may have something to do with the engine being swapped over - hence the solution not being as simple as we think.
Would appreciate any ideas really before we take it back in the morn.
