Emissions Fail - Be warned
Car  182 Clio
This is my first post and I apologise that its quite a long one.
After the the events of the last few days I felt compelled to let you know my story regarding the MOT.
My 182 failed its MOT on high emissions this week Here are the results.
CO 8.064%
HC 479ppm
lambda 0.770
I had shown these to the Renault Dealer and the MOT tester both of whom had little to say other than replace the CAT(£2000) :nono:or the lambda sensors(£90 each).
I rang my local tyre dealer to get a price for a CAT from them, only to be told they cannot supply one as Renault have not released the pattern!
Starting to panic now.:(
They did say bring the results sheet in as one of their guys can figure out what needs replacing by seeing the results.
Sooooooooooo I did just that. The guy immediately said I had a hole in the exhaust just by looking at the results above. He put the car on a ramp and showed me that the cat to exhaust clamp was loose. He cut the old clamp off and replaced it free of charge.:D
I took the car back for a retest and you guessed it it passed.:D Here are the final results.
CO 0.008%
HC 14ppm
lambda 1.029
I have been back to the Tyre dealer this morning with a crate of Cider.
So if your Cliosport fails on emissions please check all connections on the exhaust, you could save a small fortune.
Welcome !
Glad you're sorted but a decent tester would have checked for blowing exhaust before an emissions test already. Certainly should check after a fail ?
Never mind.
Enjoy your RenaultSport Clio ;)
i agree, mine failed the emissions too and the guy who MOTed it found this out and fixed it
Maybe go somewhere else next time the robbing b******s !
