Engine code number
  S2 106 GTI
Does anyone know what this number means??? 3913 I had my car diagnostic tested and it came up with - 3913 Coolant Fan Stage 2.
I thought it was the engine coolent temp sensor but when i changed it and tried the cancel the fault it wouldn't cancel! please help!!!!!!!
  172 cup'd extreme
when it was plugged in what computer or diagnostics machine was it? if it wasn't a clip then you may have problems cancelling or erasing some faults you need to leave them to go out on their own. they tend to go out if there are 3 seperate starts with no error.
if you have changed the coolant sensor also check the wiring going into it this is a common problem due the wiring not having enough play in it.
