engine fan
  Clio 182
quick question is the clio 182 engine fan ment to stay on after the engine is turned off? because mine does it all the time!!! is this normal?
and the when i lift the bonnet up there is a lot of heat in the engine bay much more so then my old 206 lol
regards
Stop driving like you stole it, then it'll be fine. Lol.
You want the fan on, it's cooling it down. If it wasn't on, you'd have far more problems.
  172
If your not driving like a maniac, any warning lights apart from high temperature? Check your water/coolant levels.
  Clio 182
funny think is im driving it normally e.g. 30 - 40 mph around town to the shops and back etc it is quite warm to day tho, and the coolent is fine at the max level and its puming around when the engine is on
no warning lights etc
just changed the coolent temp sensor cuase the other one was screwed
so the car is running sweet again
regards
DrR
  VW Golf GTD
As far as I'm aware mines not come on in 5 years I've been driving mine. Apart from when I do coolant changes.
