Clio Sport
Hi everyone!
I bought my Clio sport about a month ago and all I have done since i bought it is spend money on it fixing it! :dapprove:
My engine management light is stuck on constantly and when driving the car, it seems to hesitate a lil bit in 2nd and 3rd gear between 2 and a half thousand revs and 3 and a half thousand revs. Then when its passed 3 and a half thousand revs, i can feel the engine speedin back up again then.
Does any1 know what this might be? :S
I have changed the coil pack and leads, spark plugs pretty much everything but i just cant find the fault.
Also, when i turn my steering wheel left or right even if i move it a slight little bit, all the front end of the car makes a big loud creaking noise. Any ideas what this might be? Ive bought Anti Roll Bar Links and a driverside driveshaft, do u think this will cure it?
Also, im gettin alot of electrical faults with this car. When i indicate or brake, my back fog light in the dashboard comes on. Also, when i pressed the horn down for about 6 to 8 seconds, there was loads of smoke comin out of my actual indicator/horn/foglight stoke.
Its a 2001 1.2 16v Sport model.
Do u think there are major faults with this car?
Any helpful suggestions will be much appreciated!
Thanks everyone!
x Stacy x
:rasp:
Thanks everyone!
x Stacy x
:rasp:
