Clio 182
Right then, only had the 182 for a month and I've got a bit of a problem.
The yellow (bottom right hand corner) engine management light has come on the first time I let the wife drive it.
It's only done 40k so it's a little complicated when knowing what needs attending to. 40k miles and 11 years doesn't usually happen.
Got the coolant changed last Thursday (it's about 1" above the max if this matters) and now the light has come on. I've run the secret on-board diagnostic tool and got the message "t", I've cleared that fault but the management light is still on. The t stands for "an injection fault has been detected for a minimum of 4 seconds".
Anyone got any ideas before I have to give in and take it to a garage?
Thanks in advance.
Thanks in advance.
