exact braided brake hoses
  Lionel Richie
are these the ones that you need to file out the holes in order to fit them?
£45+vat for mocal ones from me, which is about the cheapest 100% stainless lines you'll find, and they fit perfectly
  CLIO PH1 172
yes fred they do mention this
"Note: The brake lines need to be fed through some mounts in order to reach the connectors at each end. The metal fittings on the Exact braided brake lines are larger than the oe moulded fittings and therefore require the holes in the mounts to be enlarged slightly. This modification to the mount will not affect the structural integrity of the car."
but they cost £24 posted which i cant find anywhere even 2nd hand, i just want to know if they are any good i dont mind enlarging a hole to save £20+
  Lionel Richie
LOL yeah good luck, i'll give you £20 if you can fit them in under an hour, you'll be at it for 4 hours, that's my prediction - worth £25 saving?
