Exalto 2’s How long do they last
  RX-8
Covered 11k since May and looks like im gonna need a new set by 12-13k as their almost at the tread wear indicator, just wondered how every body else was getting on?
  clio 172 MKII
4-5k ive had 2 sets of contis and a set of goodyears on the front of mine....expensive game
Theres not a lot of point asking anyone cause it all depends how you drive:cool:......................Im sure you could rag it down to a couple of hundred if you like eh;)
Cheers Stu
Ad
  MK2 FRS
Quote: Originally posted by badinvincible on 16 November 2004
Depends how you drive. I drive like Im driving Miss Daisy so my tyres last an age.
me too:oops:. My exalto1s are due for changing on the front and ive had nearly 18k out of them!"!
  RX-8
I agree depands how you drive but I dont usually chew up tyres in 12k, either my drivings changed or they just dont last.
  Ford Fiesta
my front prob another 6 k so around 12k all in, back too prob around another 18k so 24k all in, but getting back 2 changed tomorrow anyway. keeping one good one as a spare for a new alloy.
  Silver Fabia vRS
Im at 10k and the fronts have about 1mm till they are on the wear bar. I reckon another 1-2k until I need to change which is good really considering I have been hooning it everywhere!
The rears are fine though and I reckon I could probably get 30k out of them!
  williamsclio.co.uk/forum
My set are in my room being used as a table....i recon they will be good for generations....
They are getting fitted in March so most of you guys here will be on your 3rd set by then....lol unlucky.
dk
  911 GTS Cab
mine have lasted very well, i treat them mean and they keep me kean!
I have done 3 trackdays with some very hard driving and cornering on them and they lasted 13k which is very good as I couldnt really have treated them any worse.
  CLIO 197 Ultra red
that seems very good. if i get that ill be well happy. i usually swap front to rear every few thousand miles to even the wear out.
nooooooo dont swap the the rear unless you fancy the back end snapping out on you. there is nowhere near as much weight at the rear and it will have a tendancy to swing out if you have the tyres with least grip fitted to the rear. always have the most worn at the front
  CLIO 197 Ultra red
well in the dry its reversed... worn tyres are grippier cos the treadblocks dont move as much and the contact patch is greater. in the wets is more dangerous like
