Exalto 2 tyre pressures
  Orange 182
Just realised I cant find anything that tells me what the required pressures are for my 182 tyres! Anyone know what they should be?
Cheers.
  Ford Fiesta
when u say your 182 repaired what was up with it?
wernt the 172s running at 32 psi front and 30PSi rear I think I remember a post a while back about it.
  Ford Fiesta
the cup tyres with stiffer sidewalls are they the same size exactly as standard 182 tyres?
wont it be in manual for 182 and 182 cup tyres, should give you the precise pressure.... important to have them spot on peeps....
You should have a thinner seperate manual just for 182, I had same problem till I looked through my folder properly
dk
  911 GTS Cab
yes there is a separate lttile booklet for the 182 (although the picture is of a 172 with the twin exhausts!) Will have a look in mine in a mo 4 ya
