exhaust for a dci
  Burgandy 174 sport t
anyone got one?? wat one should i get?? looks wise and performance???
p.s gotta fit under a 172 bumper
Get a big pipe and run it from the exhaust manifold out ot the back of the car.
Cheap as chips but be carful with remaps you dont want to get pull for pumping out black smoke every where.
Not to many exhaust though best get one made up for the car.
There was someone on the forum a while back who had a tunning box and with the supplied rear exhaust part made 90hp but I never saw any pics of it.
EDD
65 - 90 doubt it, ive seen those boxes for 300 notes but it dont do anythin for me! end of the day its slow and always will be!
Yepe I agree with you about the 97hp being a bit high but the owner said thats what it did on the rollers at the superchips place.
The 1.5 will always be relivivly slow its a small engine but being a turbo means more power is alaiable unlke the 1.2 16V
The 65 gives about 70hp as diesel seem to generate more power after bedding in. The 80hp gives 85 hp.
The superchipped car will have a full remap ie not a tunning box which just increases flow it will also increase boost which is imortant to allow the fuel to be burnt and stop the car beltching black smoke out.
To get almost 100hp from a stock engine means boost must be up around 1.2 bar which means intake temps are around 140degrees which is to much. Should be intercooled if you inted going for this power level. (dropping an big intercooler into the car will giv move power as well)
Im suprised someone hasnt brought out a tunning kit for the DCI I expect 120hp should be easy to obtain and 140hp or so relively easy the box is strong and the internals on all versions are the same and hold back 200lb torque on chipped 80hp versions (the 80 has an intercooler due to higher boost levels of 1.1 vs 0.9 for the 65).
EDD
