Exhaust Lamda sensors
Geewhite32
  Clio Cup 172 2002
Me again,.
I had the fault's on my ecu cleared.
It's back on after 6 miles.
I had a new cat fitted and two new lamdas fitted.
Do they need mentioned to the ECU?
One of the fault's mention a pre cat faulty one ..but both new?
Cheers.
Graeme
MRBILLYUK
  FF Jeden Osiem Dwa
Me again,.
Cheers.
Graeme
Genuine Bosch lambda sensors or cheap ones?
Steering Colin
  172 Cup
If your car had a pre-cat lambda fault it would be driving horrible,
I've had a post-cat lambda sensor fault but it didn't effect how the car ran.
I wonder if you've got a hairline crack in your manifold? or you've been unlucky with crap lambda sensors?
MRBILLYUK
  FF Jeden Osiem Dwa
Genuine Bosch.. . I think about £120 for the two but would have to check
If you've used genuine Bosch lambda sensors I'd be looking at your aftermarket Cat?
When you change a lambda sensor the ecu picks this up and there's usually no need to clear the old codes.
