you shouldn't be going fast enough to lose control in the wet in the first place is my view!
exactly, i share the same view which i state in my post, if youre credentials for buying a tyre are simply how good they are in the wet then you are only a few years from death, no tyre, bar none will give you great grip in the wet, the only way to stop death on wet roads is to reduce speed accordingly.
i dont believe that a tyre that grips well in dry doesnt grip respectably well in wet, a poor dry tyre will give poorer wet grip.
Therefore, back to my above post, i base my tyre purchases on dry gripping knowing if they are good at that then they will more than likely be half decent in wet, but as with any tyre, will need some common sense driving in wet, anyone who thinks they can drive as fast in wet connditions as they can in dry, no matter the tyre choice is sadly disillusioned and a victim of manufacturer tech jargon.
and to say you want tyres to give grip in wet in cases of heavy braking (i.e, car in front brakes suddenly), provided you follow the simple rule of increasing the distance between you and the car in front during wet conditions you wont have to brake any harder than you would if the same incident occured on a dry road.
common sense really but sadly overlooked by many folks
Ive had a few bevvies tonight and probably made the same point in every paragraph so i do apologise.
the point is, if you buy a tyre so you can push the cars limits that wee bit further in the wet then the sad fact is the grim reaper is sharpening his scythe and waiting for you.
