Hi can someone please tell me what position the crankshaft should be in when setting tdc. I have seen somewhere that the woodruff key is at the top and somewhere else it says at the bottom , if I fit the crank locking pin the number 1 piston goes a couple of teeth past tdc. Whereas if I set the key way to the top I can get tdc on number 1 piston , ,,, confused ! David.
