F7R710 crankshaft bearings
  Renault clio wiiliam
Hi guys , another question since i am in process of tearing down my f7r710. So i purchased a f7r motor from megane with 98k klm , and i want build a motor with stock internals but with performance camshafts , pulleys maybe springs and increased compression. My question is what crankshaft bearings to choose , since i have read that you may need to get 4 sets of oem renault and build one set from them when i measure tolerance on the crankshaft. Also if there is anything else that i need to know please tell me since i am very new to motor tearing down and i dont have knowledge of renault motors
  308
Typically, for the F7R engine, Renault OEM bearings come in different grades or sets to match the crankshaft tolerances. When you measure the crankshaft, you might need to select different bearing sets for each journal depending on the tolerances. Renault bearings have different colors or codes (marked on the bearing) to signify their size and tolerance. For example, they might come in sizes such as Standard, 0.25mm over, or 0.5mm over.
  308
Typically, for the F7R engine, Renault OEM bearings come in different grades or sets to match the crankshaft tolerances. When you measure the crankshaft, you might need to select different Insulated bearing sets for each journal depending on the tolerances. Renault bearings have different colors or codes (marked on the bearing) to signify their size and tolerance. For example, they might come in sizes such as Standard, 0.25mm over, or 0.5mm over.
OEM bearings are usually marked with colors or alphanumeric codes (e.g., A, B, C) that represent different thicknesses or tolerances. The markings help identify the exact grade without re-measuring every time.
