FAO All Photoshop experts!!
Car  FTO GPX 2.0 V6
Hi wondering if anyone can help and tell me how you can put 2 jpg's together to create one picture. I have a pic of each of our cats, but none together and my girlfirend wants a pic of them both for her work screensaver. Any idea how to merge the 2 together?
open both images together...
Click the 1 you want to move...hit V then physically drag it onto the 2nd image.
Once on top select the eraser tool and rub away what you don't want.
Thats the billy basic method.
im thinking your after taking a sunset/landscape pic and using both to get a better effect.
Open PS. make sure both images are over each other, and then experiment a bit, in the layers tab, right click the top layer, and select bending options, turn down the capacity. Try doing the other one as well. might be worth a try.
Also the "billybasic" method Plenetx is talking about too............
stick em both on top of each other then use layer mask to blend the two together might be a bit difficult to do but depends on the images, wold probably be easier if you grayscale them both making the backgrounds easier to blend
once you have dragged the pic onto the other pic......how do you make the draged picture smaller?
eg: when some people modify cars on photoshop, they show the original picture unmodified in the corner, a lot smaller.
Martyn G
hit V key
At the top of the screen you see a box labeled.....show transform controls.
Tick this box, And the bounding box will appear.
Grab a corner whilst holding down the shift key and simply drag in or out to desired size.
Once happy hit the TICK at the top right of the screen.....VOILA
cheers for that! it's worked.
Sorry for goin off topic aswel Glyn. Hows your pic goin?
Hi,
Just seen the replies. The pics I have are
I really want them equal sizes but just next to each other. Thanks for the info I'll give it go!
