FAO anyone with a valver
  2004 Racing Blue 182
does anyone elses powersteerin resevoir leak upwards, or is it meant to do this??? i notice that i top it up, clean the resevoir, then a few days later its screechin like a b**ch, and all greasey on top again!!!
help me sort this problem please!
-->BV
Mine too, can be embarrassing! All the neighbours used to peer out of the nets when I first bought it..........sounds like a hippo getting its back doors kicked in!
  Volvo S60 T5
pas pumps are a common fault on the valvers, bit of a b**ch to do around 3 hours if you know what you are doing(PM me for info).;)
when i 1st bought my valver it used to screeech! so the garage advised me to use some power steering fluid & conditioner which stops leaks and squeals , i poured a bit of that in and it stopped straight away !
Is it smooth and sleek and not flyaway any more then? ;)
3 hours !!! thats a lot of soddin tea breaks !!!
  Mr2 Roadster
Quote: Originally posted by pmitchell on 26 October 2003
Bleed the air out the system by turning lock to lock a few times.
Common thing is for PAS fluid to seep from the small pressure relief hole in the top of the cap. Due to excess fluid or air.
Noisy pumps are commonplace.
Paul
Yep do it in the wet or on some grass or sheet metal to reduce the strain on it! OD it about 10x lock to lock!
  172 Cup, V6 255, Williams
Paul
