fast road setup
completely dependant on how you want the car to be.... there's no 'setup' that you'd use for fast road.
From my research something like 1.5 deg camber, a little bit of toe out and as much caster as you can get if you fancy going for solid top mounts.
The rear is pretty decent as it is, although a little more negative camber wouldn't hurt.
I've read about it a couple of times and thought that it was, I don't know how to explain it, something you could ask the shop to do
