Racing Blue Clio 182
Recently swapped the front seats out of my 182 and put some Recaro ones in. Had the airbag light on so have fitted resistors in the seat airbag plugs, and also put a resistor in for the passenger seat belt pre tensioner as someone had previously chopped the plug off. Had it plugged in the diagnostic machine at my mates work and deleted the fault codes and all is good....... expect for one code that I cannot get rid of......
Fault code 179 - front side sensor circuit, driver no signal
Having look on the net it seems to refer to the drivers side impact sensor under the seat. I have located the sensor and checked the plug is in firm and it seems to be. So why now am I all of a sudden getting this code coming up? We went nowhere near this sensor when fitting the seats and it wasn't showing up as a fault before I replaced the seats.
