Fault code 3623 .
  clio 172 phase 2
I had a diagnostic check today . This code came up . 3623. Somthing about solonoid inlet
Manifold open circuit could somone explain this.
Also brake switch malfunction is this a case of replacing the brake pedal switch ?
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
That code means nothing to me so i'd need to know what was used to get it from your vehicle. The only solenoid valve i can think it refers to is the EVAP solenoid valve.
Mick
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
That'll be why the code makes no sense then buddy. I was half expecting you to say it was an old Snap-On bit of kit but the Bosch units use there own code system to so you will need to either use the kit again for an accurate translation or get it redone on a proper bit of kit rather than an over-priced p.o.s.
Any symptoms or just an MIL on?
Mick
