Am I right in saying that this is duff injector on cylinder #1, I have done a ohms test on all injectors all came out with a 16.1 reading apart from #1 which was 0.47, if so where is the best place to get a full set from
Clio 172 2002
yep plug was disconnected to check the ohms reading, tried to test the connection plug to see if there was any voltage (ignition on) but could not get any reading should i be getting about 10 volts ?
