fault codes any ideas
Car  clio 182 ...........
just plugged code reader in and im getting a fault code of p0130 also says 02 sensor circuit bank 1 sensor 1 thanks marc....
yeah i think the wires are just different lengths. so you could swap them over as the 2nd one doesn't do anything
so if one sensor is is not working swap it with other and it should work is that what your saying:)
correct, all the second one does is the emissions light on the dash.
I have the same fault reading on mine.... if it is the post Cat sensor (that does not effect performance etc) will the EML stay on? My light went off after I plugged code reader in then came back on again a week later.....
Any ideas?
the second sensor does do some thing but doesnt affect performance, it sends a signal back to the ecu with info on how the cats performing. so if you swap them you might end up with another code e.g p0420 cat performance below threshold. testing the sensor is the best way to check its faulty but that code can show that the mixtures wrong or an airleak etc....
