Fault list?
  172 cup
Can anyone direct me to a list of common/possible faults to look out for when buying a 172 ph1/ph2?
Thanks for any help!
Dean
  Megane RS 250
Check for accidents, obviously.
Suspensions:
Old or failing dampers, bushes, top mounts, balljoint, wheel bearings, camber/toe value wrong (irregular tyre wear, but better to check the alignment with a specialist)
Gearbox: syncro, specially 1st, 2nd and 5th, check gearchange at high revs.
Interior: hazard switch, automatic lights and washers working properly. If the airbag light is on it could be some connectors or a previous accident and the airbag ecu has to be changed.
Engine: timebelt, auxiliary and waterpump changed "recently", sticking throttle. It would be a good idea to hook up a diagnostic tool to see past errors
Exhaust: mid and rear mounts, the rubber can be very old and cracked. The cat could be broken (see above, for gas warning errors)
  172 cup
cool thanks for your help. Havent been on this forum for few years, didnt see the Cliosport Guides section :)
