Have the k&n made a difference on tce? And also where have you located the cold air feed?I've had on corsas so I ant sure about the Clio it being a turbo with the hot air situation?
How much are they for the tce k&n 57i with the cold air feed piping?
So fair I've got:
16" Fx004 gloss black alloys,
Just ordered my Fk Highsport coilovers
Currently waiting on delivery.
Plans too do next:
Fk 16mm or 20mm spacers,
K&n 57i
Sprint spoiler (ktec)
Power flow custom made system
Dunno if I should change the standard back box?
Also might fit a forge dump valve :/?
The k&n 57i kit I got is is actually labelled up as the mk3 clio 1.6 and from memory was around £60.
There are other air induction kits out there that are better for performance than the 57i such as the bmc cda unit or the ITG maxogens, they are a fair bit more expensive but seem to give much better results. So depends how much you're willing to/can spend on it.
The 57i on mine makes more sucking noise as the air is drawn through it by the turbo but as for actual power difference is debatable as I never got mine rr'd before modifying the exhaust and adding the k&n so don't know what it was running before. My exhaust is the standard one but simply has both the centre and rear boxes deleted and have put straight through pipe in it's place. It's loud but I like the noise.
As for the cold air feed I simply used the standard one from the standard airbox and directed it at the filter. I have seen people route after market feeds from the same location or have run the down behind the o/s head light. Hot air isn't as much of a problem with the tce as the air will flow through the intercooler first before going into the inlet so will be cooled down first anyway, but obviously the colder it is to start with the better and if you really want to get serious then a larger intercooler can be fitted in place of the standard unit.
Dump valve is your choice really I like the noise it makes personally but many will disagree and some agree just down to personal choice really.
ps. I see you've also got the 197 top grills, they look good.
