Finding a Re-placement dCI engine???
  182 & Mk1 Valver
Does anyone know how much I could get hold of a dCI engine??
Just had news that the one in my work van (cliovan) is f**ked. Want to get an idea of prices, and cost of fitting, to compare against just getting a new van.
Being as the clio has done 150k since 04/05 it was getting close to being changed anyway.
Really not the best time of year to do either really.
Any info would be great, cheers.
  C-VXR, T8 Map 220BHP
Im no expert but id say about a grand fitted. And with 150k on the clock I cant imagine the van in working order is worth that tbh. But like I say im no mechanic. It cost my x £800 to have a REconed engine fitted to her corsa.
  182 & Mk1 Valver
Yeah thats what I was thinking around, should last a good while more too. Got to make it work to pay for itself.
Its quick enoug to swop the engine can be done in a day easy only possible isues are if you have any wiring/ecu issues if you get the wrong engine etc or the ecu is fried etc.
You'll need a Renault clip or similar to program the injectros codes though.
Second hand try renault specilaist breakers there not cheap for the engine but they have warenties £500 I think they ask for them not sure if that plus vat don't think so
  Clio 182
Wrexham is north wales.
I would try either WJ Furber (just outside shrewsbury) or Car Transplants (middlewich)
There are some other smaller ones in the area though i do believe.
  182 & Mk1 Valver
Cheers for your help guys much thanks. Its at Direct diesel at the moment, in chester. Will have a look around for engines.
