First effort with LP and dodo Rotary!
  LY 220 Trophy+IB PH1
Hiya,
Spent a few day's over the bank holiday working on the PH1 and managed to get a few items from I4Detailing so I could have a play with the Dodo rotary! After seeing some of the results people are getting from Lime Prime I decided to get a bottle and a light pad (LC White Pad) as this was the first time using a rotary (Used DA in the past)
http://www.i4detailing.co.uk/acatalog/Dodo_Juice_Lime_Prime_1.html
Cleaned using 2 Bucket method with Sonus wash Mitt and Dodo Supernatural Shampoo then dried with an Uber Yellow Drying Towel
After drying, I moved to claying using a Lime Clay Bar and Dodo Born Slippy
Another once over with the mitt and supernatural and dried again, then moved onto the polishing (Was pretty nervous at this stage!) I knew with the cleanser and pad combo the cut would be extremely low (But it mattered not, it was more for the experience than the actual end product) but ended up really surprised with the end finish (Especially the rear light's)
Pad link (http://www.i4detailing.co.uk/acatalog/Lake_Country_CCS_4_Pads_1.html)
Backing plate (http://www.i4detailing.co.uk/acatalog/73mm_Rotary_Backing_Plate_M14_1.html)
Did the entire car using a 4" pad, really slow process but it's all i had access too at this time as the larger ones where out of stock :(
Before:
After:
Before:
After:
Still very much a work in progress with loads still to do, but it is staying completely origonal (The way it should be ;) ) Those alloys are coming off as they are turd, looking at a set of F1's and the front bumper is getting resprayed ! Think the wing and lamp needs a slight adjustment too as they seem to be sitting a little off !
Thanks for reading :)
Paul
body work is looking good, will look great on oz f1's. look forward to seeing that happen :)
Cheer's mate, it's not bad for it's age no real dint's or bump's just a stone chipped front :) Finding a set of OZ F1's is become a real nightmare, I did consider Turini's but I like the "keeping it stock" look so wavered off that idea a little
Gally
Anytime dude. It's such an easy 2 products to use. Free delivery from Polished bliss aswell.
You'll only need the Jett trigger and the Acrylic prime not the kit in the link. Although it's a great kit. :)
Also on the site it gives a really good description on how to use them.
See my recent Golf Gt tdi thread to see Prime at work!
Just had a read through, Jesus that stuff don't half bring out the speckle ! Got to get me some of that !
