Fitting Rear Speakers - MK2 HELPPPP!
Hey guys, my mate has just purchased some new rear 13cm speakers for his clio mk2 (i think ph2).
As standard there are no rear speakers but I have read many threads and am very confused as some people say that there are wires but they are hard to find and others say there are no wires? Ahhhh :S
I need some help...how am I going to wire these speakers in? Are there actually wires running to the rear under somewhere or do you have to wire from the front?! If so...how do I do it?
Thanks Jack.
  Coiley'd Clio PH2
Take out the head unit and have a look at the speaker wire connection.
If there are wires for the rear speakers then there will be 8 wires in total going into this connector. if not, there will only be four.
If this is the case you need to buy some new wire and plug it in to the back and lay the wire to the back, fairly easy job to do.
  1.6 focus zetec....
Some clio's have rear speakers, some just have the wires, some don't have any of it.
Easy jon to do thought mate as said above... run the wires down the plastic trim on either side and upto the headunit...
So...let me get this straight...
First thing to do is take the CD player out and take out the power and speaker plugs. First...how do I know which is the speaker plug? IIRC the power plug has 7 connectors and the speaker one has 8?!?!
So when I find the speaker plug, I check whether it has 8 connectors or 4. If it has 8 I am in luck and there should be wiring going to the rear, but if it has 4 I will have to do the wiring myself.
If I find it is the latter, how do I connect the wire to the speaker plug for the Headunit e.g. which wire goes where (bare in mind I have around 6m or speaker wire, black and red, so 3m for each side).
If it has wires going to the rear already, where will they be?
Thanks guys, really...the more info the better!!
Thanks again!
  172
put your hand in and they should be taped up to the rest of the wiring along the bottom of the inside of the doorcard
  Coiley'd Clio PH2
Thanks again!
To add the extra wires if you only have 4 connectors you need these:
Simply crimp the speaker wire onto these and push it into the connector.
This can all be bought from here:
http://www.nexxia.co.uk/Car_Stereo_fitting_kits/ISO_Connectors.htm
