Blue4Ever said:I got some of ebay, but I had to file a couple of bits of plastic off the back to make them fit properly (easy enough).
Tells you all this in the manual by the way, can't go wrong.
fUbAr said:Properly fitting Renault ones don't come with a manual, but have the added advantage of fitting properly
acrebo said:Lol, cheers guys, about as easy as I thought it would be then!
Yeah, I've picked up some (hopefully) genuine Renault ones off Ebay so will investigate when they arrive. There were annoying little clips on the inside of the Fiesta ones which meant you had to use a load of brute force, against a flimsy wing, to wrench them out.
fUbAr said:there are clips on the renault ones, but they're quite large... plus the 172 wings are pretty solid so shouldnt have a problem.
have a set of orange bulbs ready... the ones that are in there now are white (as i found out)
quick 10 minute job
