Fitting Valver dials to a 1.4!!!!
Alright lads,
I am just wanting some advice on fitting valver dials to my 1.4, Ive heard that the only dials that I dont have are the digital oil temp display and the oil pressure and I was wanting to know if you can make them work?
Is there anywhere on my engine to read the oil pressure and temp?
Also how long do they take to fit and what tools do I need?
Cheers Danny
yeh u can fit them u will need temp sensor for the digi temp, but the 3 oil dials wont all work, the oil pressure wont unless u can fit a sender somwhere, which im pretty sure u cant.
the amount of work needed to fit an oil presure sender to any of the energy series of engines isnt worth doing as it would be cheaper to get a valver engine!
but you can MAKE them look like they are working by fixing each dial to the switched 12volt on your loom :D thats what i did
oil temp cant be too hard to fit surely
but pressure is another story, but im sure peops av done it on here!
if not hook it up to the oil temp gauage so then it will look like its workin
