White Clio 1.2 @ 172
I've been having an intermittent issue lately with the car showing a flashing ECU light & begins firing on 2 cylinders. It doesn't always happen immediately but it nearly always happens with in 5-10 minutes.
I've read some other forum posts and people mention common things. Here's what i've replaced so far: HT Leads & Coil Pack.
I've noticed that when the car is firing on two cylinders the coil pack is not giving a spark from the two far left plugs. Turning it off and then back on again usually corrects the issue.
I've ordered an OBDII sensor to try and read the fault codes.
If anyone has suffered similar and knows what cured their fault please let me know.
Edit: Could a mod please move this to faults. My apologies I've just noticed I posted in the wrong forum
