flexi pipe,
flexi pipe is basically a foil like exhaust pipe. honda use it on the civic type r. basically used instead of conventional joints. allows more movement with little or no fatigue.
You can use it if you can get it. not cheap i believe?
Yup its used on joints.
IIRC the downpipe on the clios have this, obvious reason is engine moves so it allows the movement etc...
It can be very expensive for decent flexi stuff.
