Fly by wire in a phase 1 172
KitsonRis
I am going to say no, but that is based on having to move a load of pins in the ECU plug when I swapped my Ph1 ECU to a GEN90. If it were a Ph2 it was a direct swap with no need to move pins around.
  Megane F7R
I did think this would be the case. Wonder if I can get a 172/182 ECU immobiliser removed, could use a 172 cup loom then and still retain what I need too.
Brigsy
  T.Turbo
I dont think immob can fully be removed on ph2, only virginilized to sync up to ph2 uch and key. You would need ph2 loom, key and uch to run it.
  Megane F7R
Shame as its not going in a Clio or anything that could run the dash for a clio =(
