Do a search, this is covered at least once a week!
It'll be the rear light cluster, remove it on drivers side, unplug the connector and clean up the left connection (black - earth usually) and as you look into the connection on the bulb holder - the right hand pin, clean it of any corrosion.
Refit, should solve it.
As above. It is one of most common problems on forum...and especially seems to crop up around winter. Piece of piss to sort. Just look for green connections where wire connects to light cluster on driver's side rear light. File the green crap off and should be fine.
This only happens around winter for me and has happened again this year despite cleaning the terminals last year, just another annual thing I have to do.
